It is currently Sun Aug 24, 2025 10:49 pm
PostPosted: Tue May 14, 2013 11:11 am
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
Anyone ever used this pump as a Vacuum pump for LMI bridge clamp? Is this the way to go?
http://www.harborfreight.com/25-cfm-vac ... 98076.html
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Tue May 14, 2013 11:52 am
DO NOT buy one of those unless you want your shop filled with oil mist!
I didn't buy that exact one but something similar and what they don't tell you is that oil mist just pours out of the exhaust port.
Look for an oil-less design and you really don't need many CFM to do what you need.
PostPosted: Tue May 14, 2013 12:08 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Any idea where to purchase an oilless compressor?
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Tue May 14, 2013 12:16 pm
First name: Blake
Last Name: Dixon
City: Kelowna
What about this one?
http://www.harborfreight.com/air-vacuum ... 96677.html
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Tue May 14, 2013 12:31 pm
That's a venturi type vacuum generator. You need an air compressor with adequate CFM for it to work. I don't have one personally but they work fine.
PostPosted: Tue May 14, 2013 1:09 pm
First name: Blake
Last Name: Dixon
City: Kelowna
I'm not sure what you mean by air compressor? Do you mean a vacuum valve setup on an air compressor or an air compressor designed for this specific purpose?
Thanks for your comments
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Tue May 14, 2013 2:08 pm
buy one of these from McMaster Carr or the auto parts store near you:
pulls 25"/hg -about the mid range of electrical pumps (23.5" to 29"/hg) and much much cheaper and quieter. less messy too. item #9963K21
as stated you really don't need monster truck force.
go green!
PostPosted: Tue May 14, 2013 2:11 pm
First name: Blake
Last Name: Dixon
City: Kelowna
thank for the replys
Blake Dxon
Blake Dixon
Kelowna B.C.
PostPosted: Tue May 14, 2013 3:16 pm
Blake Dixon
Any air compressor so long as it can generate enough CFM. It's a venturi vacuum generator that uses the Venturi principal to use an air stream to generate a vacuum - like magic!
